I searched and found some ideas, just lookin for more.
Loosing coolant through the overflow bottle. It is being forced out in little doses. I saw it do this while the turbo timer was running, heard pressure release and saw a little coolant on the ground under the bottle.
Does not overheat. Oil and coolant not mixed. After long cooldown when I take the cap (1.1bar) off it releases alot of pressure (figure no leaks or air getting in system). Doesnt seem to have BHG symptoms. Oil is still black, yes I need an oil change. Not blowin smoke while driving.
I know I need to do tests, just seein if there might be some stupid little thing that might cause this to happen. I've looked at the hoses and none seem to be leaking.
Note: Owning a 7MGTE Supra should include a medical warning, may cause High Blood pressure and stress. :aigo:
