Hi all, I was heading home yesterday and out of no where the engine shut off. I thought it was the TPS or AFM, so I tried to start it, it cranked but didn't start. I pulled over and checked under the hood, the 15A fuse in the main fuse block was blown. I looked over the harness and there was no evident wires touching or melted.
I had a few fuses and replaced it once, it started back up but stalled after a few seconds of running, I started it a couple of more times and it finnaly held a idle, but it wasnt normal. It was down at 500 rpms. After a min or two of idle the fuse blew, and the engine shut down. Tried another fuse and it ended to the same result.
I got it home late last night, and this morning I started to diagnose the problem. I went through per the TSRM, so far nothing is out of the ordinary except no power the to the ECU. I have eliminated the ignition switch, EFI Main relay, and TPS. Now, as soon as the ign switch is turned on it blows the fuse. I have checked the voltage at the 15A fuse, its at a steady 11.99 volts. When I get back home today, I plan to continue but for now this is what I have found to be possibly bad, so...
My question is, does anyone think this fusable link could be the cause of the problem? It looks like it is pretty messed up, so I'm heading to the dealership today to get a new one, I also plan to get some new of the 30A and 40A big boxy fues from there as well.
Hopefully that will fix it, also, where is the other fuseable link? The TSRM shows one that looks like it has a eye hole connector to where the battery should be, but I'm unsure of which is which. Thanks.
