Has anyone found the solution to this? I am also having this same problem so i figured I would add it on to this post rather than make a new one.
Im having the exact same problem as the thread starter, My A/F ratio is right where it should be for factory settings at idle, cruise, and wot until i turn the car off. When i shut it off then back on when the motor is still warm i get around a 12.5 afr at cruise and 13.0 afr at idle. Once the motor cools down it is perfectly normal again.
I have changed just about everything i can think of that would have a effect with this situation. I even took the maft basic off and went back to the stock AFM till I get the problem resolved. I have changed my narrowband oxygen sensor, And my wideband sensor is fairly new (about 6 months) and it is about 30 inches away from the turbo.
Can anyone point me in the right direction? or any tips would even be a big help.
thanks,
Jesse
