Connector and Misc. ID help needed
nctexan
268
Houston
Ok awesome thank you I will report back after hooking it up!
So the other wires in the connector are unnecessary then?
mobes
Supras are never 'done'
Bozeman, MT
Connector 1? Did you verify that goes to the A/C pump? On mine, there was one that went to the bottom for the speed sensor. It's not used and I just clipped it off. I don't remember if it looked like #1.
On mine there is a separate single wire going to the clutch on the front with a connector that should mate to the #3 connector.
nctexan
268
Houston
I connected the blue wire with red dots that comes off of the connector I labeled #1 to the #9 on the EA2 and that did nothing, so that's obviously not right. Ok, I will search for the wire coming off of the A/C clutch.
