Confusing clunk under back seat?
sean210
Father to Be
Nov 26, 2007
315
indianapolis
Just wandering if anyone has an insight of what this could be.
When I am slowing down there is a repeditive clunk under the
back seat. It only does it when I slow down and its not constant.
It only does it every once in a while.
More likely the rear u-joint.
Could be the rear section of the driveshaft (it's a double tube w/ rubber connecting them).
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
Yeah, I'd say carrier bearing is the most likely suspect. Jack up the car (use jackstands), get under it and grab the drive-shaft near the carrier bearing and see if there is any play, if there is much, than your carrier bearing is shot. Pretty common for these things to wear out.
