yeeeeps. pop off that oil cap to see if you have a smoke-stack!
D drjonez Supramania Contributor Mar 31, 2005 3,061 0 0 19 the motor city www.4cefed.com Apr 24, 2005 #21 yeeeeps. pop off that oil cap to see if you have a smoke-stack!
J JT87NA New Member Mar 30, 2005 171 0 0 42 SLC, UT Apr 26, 2005 #22 drjonez said: yeeeeps. pop off that oil cap to see if you have a smoke-stack! Click to expand... When I took off the oil cap last time while it was running there was a small amount of smoke coming out. So I guess it probably is the rings.
Boostedstr8six I have better SA than you Mar 30, 2005 401 0 16 Near Columbia, the river Apr 26, 2005 #23 Small amounts are OK. I'm not sure how much vapor can be considered "normal" though.
I IJ. Grumpy Old Man Mar 30, 2005 38,728 0 0 62 I come from a land down under Apr 26, 2005 #24 Boostedstr8six said: Small amounts are OK. I'm not sure how much vapor can be considered "normal" though. Click to expand... 7M's "puff" a bit and breathe heavy but at idle there shouldn't be positive pressure (you can feel this putting your hand over the fill hole). I have good comp on a fresh build and had to put bigger PCV hoses on as the ones I used weren't flowing enough on the dyno.
