compound turbo set up
mytmk3
643
christchurch
kneedragger85;1713035 said:
There is a video floating around somewhere of a MKIII with a supercharger (can't recall which) and either a Holset HX-52 or HX-55 some guys in Germany did a few years ago. They were having all sorts of trouble going in a straight line from 4k rpm and up. I cannot seem to find this video from a while ago.
http://www.youtube.com/user/knotannrkpg#p/u/20/0HeP-czHYT8
http://www.youtube.com/user/knotannrkpg#p/u/16/0HyhUusmQlQ
found it by mistake added it to favorites this time saw it years ago then couldnt seem to find it last time I looked
te72
Classifieds Moderator
6,611
7
WHYoming
For this sort of setup you'd be foolish to have anything but a full standalone. Piggy back a setup like this and you're likely to be piggy backing a ride back home...
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
compounding to turbo is cool and all but the heat whould be insain hell I have to much heat in my engine by and i only have on turbo
RacerXJ220
Interdimensional
Abalama
Keep it cold enough? It's not a problem with the BL kit. I doubt it would be a problem for anybody on pump or E85 levels of boost on most any motor.
Besides, there are titanium wheels and water injection ;)
toytech
Toyota certifed
Feb 10, 2009
Frankton,Indiana
Sequential is it not using a small turbo until the bigger turbo is spooled? Better curve not all at once.
---------- Post added at 10:55 AM ---------- Previous post was at 10:52 AM ----------
1j is a true twin one fails you have nothing.
te72
6,611
7
WHYoming
toytech;1715795 said:
[/COLOR]1j is a true twin one fails you have nothing.
Actually, you have one turbo that has to work that much harder to generate the desired pressure level. Happened to me when I found my front turbo's wastegate was disconnected at the actuator arm, flapping all that air down the exhaust...
Stock 2j is not a compound setup. Uses a smaller turbo to get power until the bigger turbo spools up and then it is parrell like the 1j.
Compound setup a smaller turbo spools the bigger turbo.
toytech
Toyota certifed
Feb 10, 2009
Frankton,Indiana
If parrell why does it have an air by pass valve. Have you looked at a Toyota service manual for the operation of this setup. Or find out why there are not that many boost controllers that can correctly operate with this setup?
