Hey guys well I am almost finished with the compound turbo kit for my 7M. Should be the first and only compound turbo 7M and MK3 supra in the world! As you will see it looks very similar to the Boost logic kit basically because that is the only possible way to fit it all in there! It is a small compound setup with room for bigger turbos later. Goal is to make the car more driveable and fun on the streets. It will run on pump plus meth at 25-27psi hoping to make 650ish. Has taken me about a month to build the setup after hours at the shop I work at. I am also redoing the wiring harness and making a new intake manifold in the same process so lots of work! I have to thank for Sean at Titan for hooking me up and working with me on the figuring out the parts.
Parts List for compound kit:
-Turbocomp 67mm .84A/R
-Borg Warner 50mm turbo with .63A/R
-(2) Precision 46mm gates(Small turbo 8psi, big turbo 10psi)
-3.5" DP
-AEM ECU controlling the small turbo curve and AEM tru-boost controlling the big turbo
Full mod list for the car:
-Custom front facing intake manifold w/80mm TB
-2.5" IC piping
-Full Custom 3" stainless exhaust
-AEM
-Custom Meth injection kit with 1000cc injector
-550's, Walbro, Aeromotive with all the custom lines
-6000 miles on the motor with ARP's throughout
-2J Coils and Ignitor
-All the other supporting mods as well.....
Now onto the pictures!!
Before:
New setup:
Wring nightmare:
Let me know what you guys think, hoping to have it on the dyno this week for some serious tuning.
Thanks,
Seth
-3.5" DP
-2.5" IC piping
-AEM
Before:
New setup:
Wring nightmare:
Thanks,
Seth
