I hope this make sense...OK I Have a 7mgte with a custom bellhousing behind a R151f transmission in my 86' 4runner, The problem is that I need a lot more holding power and my clutch keep slipping,
this is becasue I have a 23 spline 22r turbo clutch behind 7mge flywheel, the clutch kit is designed for the 22R turbo because the R151f is 23 spline. But the 22r turbo 23 spline clutch cannot hold the power of the 7mgte
So... I have a 23 spline input with a shaft lenth of the 21 spline, this is why I cant use the 7mgte clutch because I have to use a pressure plate desinged for a 7mge flywheel.
So here is my question: Can I buy a heavy duty, 7mgte 23 spline clutch disk. and put it behind a heavy duty 7mge pressure plate.
