bvsv's are interchangeable between alot of Toyota models..
I've also heard window switches are compatible with the 4th gen Celica..
RazoE;1051963 said:bvsv's are interchangeable between alot of Toyota models.
RazoE;1051963 said:I've also heard window switches are compatible with the 4th gen Celica..
annoyingrob;1052104 said:Do they have the auto down/up switches too? If so, I'm hitting up the junkyard next week, and modding in dual auto switches into my Supra.
jetjock;1051522 said:Not sure if it'll help but the EPC notes what parts are common to other models.
As for window speed that's simple. In the interest of safety I'll keep it to myself though![]()
PrinceChip;1051956 said:the whole thing about the faster power windows reminds me of this clip about custom power windows....
ZoomZoomZoom;1052120 said:We're all grown-ups here. For the most part.
annoyingrob;1052104 said:I'm hitting up the junkyard next week, and modding in dual auto switches into my Supra.
I know. I want a source for a 2nd switch so I can install one for the passenger window.ZoomZoomZoom;1052117 said:Your current 89+ can do auto up AND down. On the window button itself, you will find a little plastic tab that you can brake off with your fingers. Ta-da, auto up and down.
Yeah, I wanted to install two driver's side switches. The wiring's the easy part, I can install a 2nd stock controller for the 2nd window. As long as I can physically fit both switches into the switch assembly, I can wire it.CRE;1052216 said:If you mean yu want to install the driver;s side of two switches so you've got auto up and down on both sides you'll naad to install an aftermarket controller. Pull out the stocker and you'll see what I mean. There's no room for that kind of hack job.
jetjock;1052145 said:If you actually believe that you've got bigger problems than slow windows...
CRE;1051158 said:I'll see your nozzles and raise you a newer Buick. Newer Buicks and many other GM vehicles have those but the mount to the wiper arm and most salvage yards will give them to you for free.![]()
annoyingrob;1052523 said:As long as I can physically fit both switches into the switch assembly, I can wire it.
CRE;1052670 said:You can't. You're saying that you want the left switch portion of two master switch assemblies to cram into the driver side window switch area, right? No can do... have you even looked at the master switch assembly?
