Cometic headgasket; Feedback
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
I seriously suggest you check all the rivets. This is pretty easy to do, just lay the gasket down on the block and check if any of the rivets are holding the gasket up.
My HKS gasket needed a rivet drilled out as well.
M
mrfaaast
Guest
I use a Cometic gasket, had to drill a rivet but after that it works perfect.
//M
Satan
Tampa
...okay, so the block/head go to the machineshop tomorrow....
Gonna ask for RA~40 (or less). Once I go to put it on, what's the deal with the Permatex? Do I need to do this with freshly machined surfaces?
