Hey Jonny where in Boulder are you, I'm in Louisville and work in Boulder.
I've got an extensively modded '89t, with no real dyno numbers (melted a strap on 1st power pull) but was estimated around 470@4500rpm (wheels broke loose, strap melted, shit my pants). I just broke a coolent line to the turbo and have to pull it out and replace it, Suprasport sent me another several weeks ago but I was waiting for the AEM EMS to show-up before I installed it (I waited too long) and it cracked while doing a hard run up the Louisville Hill on 36, limped home and as soon as I tried to tighten it it broke off. Will be up and running soon though, and then I would be down for a CO meet.
Matt
Current mods:
SurpaSport BOSS 550 dual BB, big shaft 58 trim
Lipp SS elbow
RT downpipe
Greddy SP cat back
RT test pipe
Spearco IC
Defcon hard pipes, ceramic coated
Greddy type S BOV
Lexus AFM (too be removed once EMS is installed)
RC 550's
Walbro 255 pump
SupraSport AFR Fuel solution
Ross .17 over, ceramic and dry film coated by swaintech
Pauter rods
rebuilt head
MSD 8.5 plug wires
Irridum plugs
Greddy catch can (to be installed)
ARP head and main studs
ported exhaust manifold
K&N Fipk
PWR Rad
FAL 220's with temp switch
RPS flywheel
Spec 3 clutch
SS clutch line
SupraSport v3 short shifter
Safc 2 (too be removed once EMS is installed)
LM-1 WBo2
Avc-r (too be removed once EMS is installed)
AEM EMS (3.5bar, IAT) too be installed
ST sway bars
ROH Drift-R 17x8 (18's coming soon)
235 45 Mich pilots
Brembo cross drilled F+R (BBK coming soon)
Metal Maxis pads
Goodrich SS brake lines
Eibach and Tokico II's
F+R greddy strut bars
Leatherseats.com leather and seude interior
Lotek dual pillar pod, with Auto meter boost and egt
Shine auto replica East Bear lip (to be installed)
