Cold Starts like GARBAGE
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
i don't know when this started...
it started when i moved to my new place in PA...if that makes any sense...
but when its cold and i start it...the rpms climb sooo slow and it stumbles and it misses and its a mess and after ten seconds it evens out and is fine. anyone know what the problem can be? i cleaned the cold start injector a while ago...what else causes this...
i'll try to post a video up once i get a video editing program.
mrnickleye
Love My Daily Driver !
Jun 8, 2005
825
Mojave Desert, Ca
We are getting into FALL weather. Its not hot, nor cold. The cold start injector won't work until the engine temp gets down to like 50*.
I recommend putting some Techron fuel treatment into your tank, (2 tanks full) which will help clean the injectors and valves. Either of which, if dirty, will cause your symptoms.
When the temps start getting colder, it will probably start fine.
89Turbo
804
Portland
dude same, plus mine is on like the 2nd or 3rd crank
mrnickleye
Jun 8, 2005
825
Mojave Desert, Ca
What happens is this...
Carbon build up on the intake valves will act like a sponge upon startup. It soaks up some of the fuel, and causes a bit of a lean condition, until the engine runs for a few minutes, and the carbon gets saturated.:icon_bigg
KINGPIN33
183
Canada
I got the same problem! I cleaned the cold start injector and checked the cold start timing switch etc...
One thing I did find was that it started up fine when I just charged my battery and put in the car. My battery is dead 1/2 the time because i don't drive it. The car would only start on like the 2nd try. I would have to put the key in crank for 3 seconds and then release, then crank again and it would start then stumble and miss horribly like you've mentioned and then be all fine after 10 seconds or so.
Maybe my problem is different then all yours but make sure your battery is strong and pumps out good amps to crank that engine well.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
Mine did that, would run fine, but youd have to reallllly baby it for a few miles.
Coolant was getting into the CC... my headgasket was seeping coolant after shutdown.
johnathan1
Supra =
Aug 19, 2005
5,056
My car does something similar...I have to crank for about three seconds, and it will idle really low, like at 400, then slowly rise to about 1200-1500 RPMS, and it seems to idle and run fine after that, I cleaned my CSI, replaced the Time switch and evrything...
ians13
537
Jacksonville, fl
what is cc how did you fix the problem.
ians13
537
Jacksonville, fl
is it possible to have a BHG and not over heat at all, the car runs great and boost great. is it possible to have a BHG ans have no symtoms
935motorsports
San Diego, CA
EFI water temp sensor.
The green one behind the power steering resevoir, if turbo.
Will cause a shitty cold start if it is not working OR the wires to it have broken off.
ians13
537
Jacksonville, fl
it has been replaced with a brand new one and new wires new connector.
ians13
537
Jacksonville, fl
Wills7MGTE said:
mine does it too, and its annoying but only does it if it sits for a few days of not driving, occasionally when its 60 or so out ya know.
mine does it almost all the time hot or cold and i drive my car every day.
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
doesn't it worry you guys? it sounds so sick..and not the good sick. i remember when got my car to start beautifully a little while back, it put a smile on my face. now. man..
