My car has had this misfire after cold start for as long as I can remember. I have rebuilt this engine twice, have had stock and different piggback computers on it, and it has always done it. When I get in the car in the morning and drive off, the car feels jerky in first and second gear right around 2000 rpm and it is quite annoying. After 3-4 minutes of driving the misfire is completely gone and the car drives normally, but every time I drive off in the morning the car is jerky for the first few minutes, almost feels like when you let go/reapply the gas on a manual trans car and the car bucks back and fourth.
The colder it is outside the worse it gets, in fact, in the summer when ambient temps don't drop below 100, its barely noticeable, but when it gets cooler out it is very noticeable.
Things I have checked or fixed include:
Fixed any vac leaks, vf voltages are normal once fully warmed up
Replaced injectors with RC 550's
Replaced CPS with NEW
Fixed all broken connectors on the harness
Grounded the igniter
Adjusted TPS
Set timing to 10deg
Checked plug wire resistance/inspected plugs/checked ignition coil resistance-swapped coils for another used set, made no change
My current setup is 550cc injectors, AFPR, Walbro FP, stock AFM with SAFC, recirculated bypass valve, rebuilt engine with all valve adjustments checked. Like I said earlier the problem was always the same, even when 100% bone stock, and even when I used a MAFTPRO with speed density.
Not sure what else to check. I have basically put up with this problem for as long as I can remember but I would really like to fix it.
Here's the vid, you can see it misses right between 2000 and 2500 RPM, if you go above or below that it generally will not misfire. At ~2200 rpm, it feels like I have to really press the gas hard for the rpm to increase just a little bit, almost like the engine doesn't want to accelerate. You can see my vacuum gauge and A/F gauge. AFR sticks around 14.7 as expected.
http://www.youtube.com/watch?v=zqSSXIycL_M
Forgot to mention that there are no stored codes.
Thanks let me know if you have any ideas.
Adjusted TPS
Set timing to 10deg
