Yea, fuel will come out, but it will dry up and evaporate pretty quickly...You shouldn't mess with that CSI fuel line too much, I barely moved mine, and it broke off completely from the fuel rail... had to replace it, so be gentle with it!
Take off the banjo fitting to the CSI, then take off the two bolts (or maybe they are nuts?) and take out the CSI, while removing the connector at the same time. Should be fine.
Note: You will need a new gasket for it once it's off...
