My knock code only came up once in a while, at high rpm. It didn't seem to have any affect on the engine though. I had removed the knock sensors to inspect them for cracks in the plastic connector, and they looked ok, but I just threw in another pair from a known good engine. Then the harness was replaced when I went with the maft pro because it had other damaged areas on the old harness. Then the knock sensor code still came up once in a while, so I tried another ecu....actually a few different ecu's. So at that point, even though swapping out parts may not be the most efficent way of troubleshooting, what was causing it? At some point I did get out the o-scope and both sensors looked to have the same type of voltage and waveform.
