code 51 & safc question
j3r3my
240
mass
Ok so I have 90% of my problems fixed so I have code 51..guessing tps is out of wack/junk? And my safc says 28-30% throttle no matter what I do..and for the afm it reads 0-3hz...also when I try to rev it doesn't let it just bucks..can someone help a brother out?
j3r3my
240
mass
Well it would seem so but..its def wired up correctly..and it still does the same even without the safc..
whitemike
1,164
Winter Park, Florida, United States
Code 51 is your IDL circuit for the TPS. It's also the only live code.. Meaning if you fix it, the CEL will stop flashing that code without clearing. The IDL circuit is open when the throttle is opened slightly or your tps is out of alignment.
Mike
j3r3my
240
mass
ok but why isnt my safc reading the afm? also why is it read 28-30% throttle?
---------- Post added at 08:15 PM ---------- Previous post was at 08:14 PM ----------
and why would it die out when i rev it?
j3r3my
240
mass
yea the safc is 100% wired correctly..like i stated before with or w.o the safc it runs the same.....
j3r3my
240
mass
the SAME way my dude...i removed it and its still the same also idfk what it could be...if i try to rev it it will either bog/die or break up upon reving
