3p141592654;1463700 said:AKA no such thing. I have disassembled the ECU code. Your car computes fuel primarily from the AFM and RPM. Everything else is a correction. TPS is used only for transient throttle events. Don't believe me, disconnect the VTA signal wire and go for a drive. You will not run rich, you won't even know its disconnected because it will drive normal. Most of these cars no longer even have a good VTA signal due to flatspots worn in the TPS potentiometer trace.
I agree with everything said above but wouldnt that result in a excessively rich correction that would be temporarily experienced during throttle increase?
