I have been getting a code 52 intermittently for some time now. I am still not convinced it is the wireing, because if I let the car warm up to running temp before driving, no code. Start and go, I get the code almost everytime. Tired of dicking around, so it's time to do it.
I recently installed a MBC, and it is set for around 8 PSI, works great. Now I also get a code 34. Even if I never see boost. If the codes are not stored, where is it coming from. Is it the same sensor for the gauge that would indicate an over boost situation. I have found a couple of boost leaks under the new pressure, which are now corrected, I have a MaxSpeed BOV, and it appears to work perfectly as well.
Any ideas?
Any ideas?
