code 31
terror
Antibliss
Jun 13, 2008
242
Alaska
so magically i was workin on my car and then i went to go eat some chicken and when i came back i had a check engine light-code 31- Air flow meter circuit or Vacuum sensor signal fault, :( . i think this has something todo with my map sensor or wiring. so i checked the wiring and it was ok and i was wondering if anyone knows how to determine if the map sensor for the 1jz is bad and where i can find one. thanks
GotTurbos?
2J = Here; Swap = Near
Apr 24, 2006
951
Dallas, TX
Zerocool;1168659 said:
if your map sensor is bad your car wouldn't run correctly or at all I do believe...
Yeah, if you have no map sensor plugged in, your car is going to run like absolute ass. I forgot to hook mine back up once and noticed immediately.
terror
Antibliss
Jun 13, 2008
242
Alaska
well thats how its running, really rich as if the ecu is on a fail safe mode and upon slight throttle it almost cuts out, But i want to know how to test it before i buy a new one, if i can find one. thanks
