I suppose it could be the FET, IGBT or whatever the driver is. If we could only get the OP to make sense of his measurements at the connector. And what kind of chicken meter doesn't do dc current?
jetjock;1942210 said:That can not be. There can only be one or the other.
noshine;1942252 said:Yep, with the sensor pluged in to the harness, you can read 12vdc from each black wire to the battery ground.But unplug the 02 sensor and only one of the black wires reads 12v and the other is the ground. If you check voltage on the two wires,while the sensor is pluged in there is NO voltage beween the two wires.. It like it a dead short with the sensor pluged up. but no fuses blow?
noshine;1942252 said:I got to do a little more testing yesterday. It seems the HT pin is not grounding. If i've been reading correctly the ECU grounds it internly? Is there any way to check it or just try to find another computer?
