code 21 engine light on only when cold
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Nothing says they have to listen but I assume some here want to learn more about how their cars work. Other than a faulty heater when dealing with an O2 code you have to ask yourself whether the sensor is bad or simply doing it's job. There are lots of problems that could occur in the system to shift the sensor signal one way or the other, even driving it full lean or rich and keeping it there. In other words a bad O2 signal doesn't mean a bad O2 sensor. It's why they're replaced so often without resolving the problem. That said, because of how the diagnostic system is programmed, in the case of code 21 the odds are the sensor or it's wiring will be at fault. With the other O2 codes the opposite is true but testing is the only way to know for sure.
Shytheed Dumas
For Sale
Mar 6, 2006
967
Louisville, KY
I will get out my multimeter this weekend. Thanks for the troubleshooting how-to JJ. Btw, I doubt my issue is in the harness since it was brand new as of last December and I'm almost positive the problem predated the harness swap.
BTW dcrusupra, when shooting clay pigeons with a shotgun (skeet, trap), yelling "pull" indicates that you are ready for the pigeons to be launched and shot - BAm! Mr.Yota was just having fun with the term "shotgunning". ;)
88YotaTurbo
658
Wolcott, Ct.
I sure was having fun with the shotgunning :) . I use a bluepoint multimeter that is a few years old but It does a fine job for diaging continuity.
