wuld a street performance clutch kit from ACT with a 7lb flywheel be better than a pro race 4 or 6 pad clutch?
shiftysupra;1176384 said:like he said if you want only a race car get the flywheel... because since you will be able to rev quicker so will the fall, and can cause your engine to die. also keep in mind it wont give you more hp only free up some from turning the flywheel to the wheels. anotherwords you will get more rwhp but not more than your engine already has... if that makes sense
zambini;1178355 said:if its stock otherwise dont get a full race clutch. youll hate it.
zambini;1178957 said:does it really need to be replaced that bad? focus your time and money elsewhere for the time being if its not completely shot.. otherwise, i would stick to a disc as opposed to a 6 puck until youre making some decent power.
Poodles;1179213 said:Loose shifter = bad shifter bushings. get em from marlin crawler or driftmotion.
If the clutch isn't slipping, don't mess with it right now, there are better places to spend your money.
Sil;1179363 said:Shifter bushing takes maybe 15 minutes to install, do you have an r154 or a w58?
USPturbo89;1179149 said:its like its not in gear but it is ya kno.... im tryin to eliminate all the tranny problems so it doesnt break anythin else....
sneakypete;1179753 said:does this happen when your driving. what are the symptoms?
when your trying to accelerate, does it rev up higher and not pull as hard? hard to explain, but it sounds like a slipping clutch
-pete
Grimsta;1179961 said:hell yeah baby, Off road rock crawlin Supra!
