clutch?
nosman4
133
Bend, Oregon
It all depends on what your plans are for the car? Do you plan to daily drive the car or are you racing it? How much power are you making? Mod list?
shiftysupra
180
Tucson, AZ
like he said if you want only a race car get the flywheel... because since you will be able to rev quicker so will the fall, and can cause your engine to die. also keep in mind it wont give you more hp only free up some from turning the flywheel to the wheels. anotherwords you will get more rwhp but not more than your engine already has... if that makes sense
USPturbo89
COONASS MAFIA MEMBER
Nov 2, 2008
142
M-Town Avoyelles parish La.
yea i get that... lol an i do plan on upgading it alot more but ima drive it on mostly my off days and to wurk sometimes... but im just getting started on bith of them and wus just seeing about the best upgrade for the time... and the car is stock as of now so.... holla at me if u have feedback...
zambini
464
Detroit, MI
does it really need to be replaced that bad? focus your time and money elsewhere for the time being if its not completely shot.. otherwise, i would stick to a disc as opposed to a 6 puck until youre making some decent power.
USPturbo89
Nov 2, 2008
142
no i dnt think so but i have a lot of play with my shift when its in gear.... its like its not in gear but it is ya kno.... im tryin to eliminate all the tranny problems so it doesnt break anythin else.... if u catch wat i said and u kno wats causin it give me a holla bak... thanks man
Loose shifter = bad shifter bushings. get em from marlin crawler or driftmotion.
If the clutch isn't slipping, don't mess with it right now, there are better places to spend your money.
USPturbo89
Nov 2, 2008
142
true true, well ima check them out and c wat i can find... do u kno bout how long of a job that wuld b? for just the bearings....
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
does this happen when your driving. what are the symptoms?
when your trying to accelerate, does it rev up higher and not pull as hard? hard to explain, but it sounds like a slipping clutch
-pete
USPturbo89
Nov 2, 2008
142
-pete
nah it aint the clutch cuz i still have plenty accel. its just the bushings im sure... oh an thanx bros.. appreciate the help
