Installed new clutch disc, pressure plate, and throw out bearing on my 88t. Put new bolts in for pressure plate torqed to 14 ftlbs. When car back together, it would not go into gear while started.
I put it on jacks, clutch depressed in 1st gear and started her up. The tires were spinning with the clutch depressed.
Everything seemes to be put on right.
When i did take the salve off, i noticed i got the boot up and it started leaking. Put the boot back on, bled the system, and it still does not disengage the clutch.
Any ideas?
Any ideas?
