Clutch reinstalll
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
OK Well Im about to put the tranny on and Im putting the clutch back in and well, I put the disc onto the flywheel, then put the pressure plate on, then notice the damn disc kinda slumps down, how the fuck do I make it stay put?
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
you need an alignment tool...if you got a new clutch it would come with one. Its a plastic thing that looks like the output shaft of the trans that holds it in placed while you tighten up the pressure plate.
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
this has been discussed before and you don't need one, it slides onto the transmission input shaft perfectely aligned.
-Thomas
jmanbball
Yellow Jacket
Apr 17, 2006
234
Hittin' the books at Tech
-Thomas
If its a w58, which it probably is since he's got an NA, you have to bolt the pressure plate up first because there are no access panels in the bellhousing.
like rupmtis said, he needs to get a clutch alignment tool.
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
ghetto riggin time, I cant afford any more tools, any other ideas, suggestions?
Oh and I dont see any match marks on either pressure plate or flywheel.
xarewhyayen
276 whp - 324 tq @ 13psi
Oct 3, 2005
959
Philly
you could use an extension with an appropriately sized socket on the end to hold it there till you get a couple bolts tight.. worked for us (emp and I)
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
Yeah I just did that, put an 8mm in the tiny hole, whatever to 3/8 extension to a 1/2 extension, held.
