clutch problems
Oct 12, 2006
141
Chicago, IL
Good to hear the clutch problem is resolved and it bled good and everything. And maybe your clutch isn't bad, you might just need to adjust the clutch pedal.
Finnon
701
South Shields, Tyne & Wear ENGLAND
suprahero;1044721 said:
Finnon, it's eyes open, mouth shut when bleeding the clutch, not the other way around........:biglaugh:
haha. i hadnt even started it then. i had a bottle of pop (soda to u guys i think) and my bleed bottle was the same type of bottle. i didnt look properly and well guess what i did.
Finnon
701
yeah, the master cylinder is old. But the slave looks brand new. so i dunno. i doubt they were unable to bleed it. it will probably be leaking slowly from the master seals some where.
I take it the pedal adjustment is on the top of the pedal itself? ill check the tsrm anyway
Oct 12, 2006
141
Chicago, IL
Yup its at the top of the pedal, but the tsrm should tell you how to do it.
