sometimes when you just let it hang the piston will come out too much and leak/introduce air into the sytem. Just bleed it and make sure your fluid level doesnt drop too low, keep an eye on it and refill as necesary(sp?). If that doesnt work either you installed the clutch fork incorrectly or you need to replace your slave cylinder. hope that helps.....................
well i figured it out.. i let a friend put it back together;the fork and the piston push rod where not in a line....there also was air in the lines.. so lesson learned.. friends can help but check their work...thanks so much for helping out...
