clutch pedal firmness
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
I recently test-drove a M/T MK3, and when I went to engage the clutch, I had to put the pedal all the way to the floor.
Is this normal or should the pedal be more firm?
Thanks guys
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
I'm not sure. It's a MK3 I'm looking at buying, I can ask the seller tomorrow.
I looked at the master and it looked to be pretty full. Also, when I checked under the car for leaks I found no spots on the ground.
Nomad707
Im From The Bay
Mar 14, 2007
1,039
Santa Rosa, California
then the fluid may be bypassing inside the master cyl. theres a seal that can be letting fluid past, resulting in crappy disengage, OR there might be some air in the system, Hard to tell from my side.. just make sure to check it out thoroughly before purchasing. its not bad replacing the slave cyl or master cyl. How does the clutch feel itself? does it slip?
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
You know, I honestly do not know the answer to that question. It was only the third or fourth time that I'd ever driven stick, so I don't even know what to look/feel for.
