CLUTCH ISSUES PLEASE HELP!!!!!
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
supraman16 said:
I'M GOING TO PULL THE TRANNY I THINK THE THROW OUT BEARING SNAP RING CAME OFF.
Yup, same thing happened to me a few days ago, tranny is still out. Go to Toyota and buy all new rings and a new hub, its about $105.
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
supraman16 said:
Thanks bro. I already ordered the parts with a dealer to dealer discount only cost me 26.00 bucks
What would have been the total without the discount? If its $105 then dang you got a mad discount.
1988SupraDreams
509
San Jose, CA
Clifton said:
Stock PP is fine with a 6 puck. It will easily hold 500+ rwtq. I started to slip at 28 psi with that set up. A stiffer PP will increase the torque if you need it, if not just through the disk in.
Your car makes me drool... Just thought I'd let you know :biglaugh:
supraman16
SUPRASAVER
Jul 23, 2006
68
Atlanta
It's been a long pissed off day. I pulled the tranny out today at th shop
took about 45 minutes. Installed new pressure plate hub release and
all rings. Drove about 15 minutes felt real good. pulled it back in the shop
put it back on the lift to check for leaks, all ok put the vehicle in gear damn
pedal went to the floor fluid all over. Slave blew out again rings also came
of of release hub. Will be pulling trans out again. I found out the release hub is worn off snap ring came off. I'm sure the culprit is the imput shaft must have play or is bent or the imput shaft bearing may be damage, must ahve done it while installing the JDM engine. Who ever reads this DONT BE A DUMB ASS LIKE ME!!! CHECK EVERYTHING!!!!. I was so pissed today I almost sold the car, but then a EVO customer came in today, that reminded me how I love punishing those cars.
