Anyone ith any ideas please help. I have been fightingthis mkiii for a week.
last Sunday I pulled out my drive way shifted into 1st going into 2nd pedal went to the floor, I found clutch slave pooring hydraulic fluid. I replaced slave
and bled the system, clutch pedal was so tight it would allow the vehicle switch to be engaged to start, I found a faulty master cylinder. I replaced master and bled system vehicle now starts. The poblem Im have is the vehicle will not go into gear and grinds only when trying to engage reverse.
Does not grind when trying any other gear but will not engage. the clutch, pressure plate throw out bearing is only 4 months old. Installed a JDM engine
3 weeks ago. I need to know if I'm doing something wrong or missing something. Any help would be apreciated. (LETS KEEP THESE MKIII'S ON THE ROAD)!!!!!
