it currently has a new slave cylinder and master cylinder. but when i try to use the napa bleeder when i try to push the pedal down it pushes fluid out from the threads. therefore wouldnt it also let air back in throught the same spot??? im just curious. cuz this is the only car i have now other than my wifes camry.
oh and you can get a new slave cylinder from either autozone or advance for like $25 or from carquest for $30, but im guessing im going to have to pull the clutch out and replace it if i cant get this bled out right. thanx for the help.
