clutch help!! please!
supra88gr
110
s dub
so we finale had a nice day in CT today ( 50 degrees :biglaugh: ) so i went to take my supra out for a ride and when i went to go start it the clutch pedal just plays back and forth very freely and does not engage for some reason so i checkt the fluid and it was fine what ls could cause this to happen ?
moonpie33
61
castroville
could be the clutch but if it stays to the floor it will be your master/slave
replace both and bleed clutch
i know on the mk2 when one goes out the other goes out
gelboy1015
Vroom Vroom!
Jan 1, 2007
234
Houston, TX
clutch master cylinder, or slave cylinder... and when you change one, you gotta change the other. i didnt change either after doing my clutch and a few days later i lost pressure on the way to school, and the clutch wouldnt disengage. it sucked
moonpie33
61
castroville
well it will engage if the clutch is pulled out and will disengage if the clutch is pushed in. the pedal just wont come back out or in for that matter.
at least yalls parts are cheaper.
you can drive it if you pull the clutch out each time you shift. i dont sugest it but it can be done.
gelboy1015
Vroom Vroom!
Jan 1, 2007
234
Houston, TX
^^ lol that what i did. i happened to have a neck tie in my bag, so i tied it around the pedal.. it was like i was riding a horse - depress, shift, pull, depress, shift, pull..
