I have changed out the slave cylinder the master cylinder, installed steel braided line all new fluid and fully bedded with the vac pump and old peddle method... Not sure what to do next:/ thanks so much.
mk3tattoos;1907489 said:If I press the brakes just a little hard before a complete stop, the clutch peddle goes to the floor as soon as I touch it.
I'll try and bench bleed them and rebelled the system againthanks for the great tips!!!! I'll report back as soon as I'm done.
IndigoMKII;1907503 said:The brake shouldn't haven anything to do with the clutch system. You can literately assemble the clutch system on a bench and it will operate as long as you hold the push rod inside the slave cylinder.
What I'm trying to say is the brakes have nothing to do with the clutch.
