Clutch Failure. Questions.
eman2289
Noob..but not incompetent
Feb 23, 2007
618
Jersey
Hi guys, first off let me start by saying that I do not know much about clutches, nor the terminology used for them, so please bear with me.
About two months ago, I heard the typical throwout bearing "rattle". I just dealt with it until recently when the car started vibrating more than normal when in neutral and when revving. The clutch even felt funny, hard to describe it. Maybe mushy would be the word.
Fast forward to tonight. I Dropped the trans with my buddy thinking that it was gunna be a simple throwout bearing. I was WRONG. Turns out one of the three "braces" on the pressure plate broke off of its rivot, spun around, slicing into my bellhousing and then shot out the side of the bellhousing.
I provided pictures to show it all.
My questions;
1: What could have caused this? Manufacturer error? Install error?
2: What can I do about it? Its about 2 years old, even though the car sat for a year. Will spec replace it? Its a spec stage 3.
3: If I must buy a new clutch, which would be best for me? I put down 457whp and somewhere around 450tq.
4: Would you replace the bellhousing? Can it somehow be fixed? If so, how?
Pics:
And how she sits now. :(
eman2289
Feb 23, 2007
618
Jersey
I was actually planning on going with meth soon. So i guess that wont be any good. Any others?
jagpride
72
So Cal
Dude that is some sick shrapnel.Dude sucks that your supa Is laying around all cold my supy is in my drive need a new clutch to.Check craiglist and tell all your buddys good luck
FullNelson
574
Coastal Georgia
Yup, and if you get one with a higher clamping force, it just might hold up to that meth kit of yours.
As far as the bellhousing, if no one here chimes in, call to a welding shop/mechanic to see if they would reccomend patching it. It seems like it would be ok to just weld up the hole and debur the other marks and you should be ok, but thats just my thinking aloud.
lewis15498
Don't blame ebay cheapass
Sep 28, 2008
1,397
Raynham, Massachusetts, United States
Nothing wrong with that, guys that do the 7m 4x4 truck swap often cut the bell housing from the R154 and an R150F truck trans and weld them together so they can use the R150F vs. a W series trans.
I would think this would be the cheapest route, but if your not comfortable with this I may have a bellhousing available. PM me if your interested.
lewis15498
Sep 28, 2008
1,397
nick88;1462036 said:
[thumb]http://i14.photobucket.com/albums/a306/mattbrobston/Picture173.jpg[/thumb]
[thumb]http://i14.photobucket.com/albums/a306/mattbrobston/Picture172.jpg[/thumb]
God damn! I dont think I would try to have that one welded up.
Did you really have to circle the damage? lol.
tekimp
Airborne
Aug 8, 2007
101
Fort Bragg, NC
did a clutch change on my Supra less than a month and a half ago.... had the same problem. Don't remember what pressure plate it was... but almost same outcome, just not as bad.
Darn high horsepower does it to these pressure plates.
nick88
JayHall's Hero
May 10, 2009
794
Des Moines, Iowa, United States
My friend was on a 57 trim ct26.
suprarich
Guest
Nov 9, 2005
2,187
ohio
It is common to nearly any pressure plate that uses the straps. It is NOT just a Spec thing. Things break when you up the HP, it is just the nature of going faster.
eman2289
Feb 23, 2007
618
Jersey
Ok, so id like to avoid this possibly happening again, I sent you back a PM rich, what would you suggest? Within a decent price range. Maybe say around 600-700 bucks.
