Clicking Noise
danielMA70
14
Germany
Hey guy´s,
i think it´s the time to take the chance to tell you about my clicking problem.
So i have a clicking sound who´s til last year but i couldn´t find anything and i need your experiences.
I thought it was one of the rod bearings, but i changed them so they are new and the sound is even there.
The sound currently appears if i throttle the engine and then after leaving the throttle pedal there is a clicking when the engine rotates with 2000 rpm to 1800 rpm then the sound is currently there....
here is a video and check it at 46 seconds there you can here it clear......
if the engine is cold its not all the time ....
please check this site
http://s109.photobucket.com/albums/n65/drunkenmaster01/?action=view&current=SDC11315.flv
http://s109.photobucket.com/albums/n65/drunkenmaster01/?action=view&current=SDC11459.mp4
i´m thinking about the axial crank bearings or the oil pump gear ....with an special tool i could hear the sound is in the direction of the second zylindre or from the oil pump ....
the tootbelt and the rolls are 2 years old and i when was driving with stock Turbo pressure
greetings daniel
danielMA70
14
Germany
The valve clearance was checked.....
but do you have an idea???? i´m very happy about every new idea......
danielMA70
14
Germany
Hi,
no it is like in the video ....
if the engine is cold there is no sound ....
engine warm its there ..... but not all the time...
dumbo
1,911
Albera, Too Far North
Honestly it sounds a lot like rod knock/piston slap but a video camera is a far cry from the human ear sorry man, and only when warm "sometimes" is a real fucker. You need a sethescope(screwdriver or something pressed to your ear in a pinch works well, blunt end against your ear of course haha) to help pin point the location.
Did you check your bearing clearances and inspect everything when you changed your bearing? It's not a exhaust leak is it?( Doesn't sound like it but..)
I'm intrigued man, good luck .
bombinuass
431
Dahlonega, GA
i have and have always had this noise and has never gotten worse but dont listen to me lol im just stating that for my own good lol. but its identical noise.
I6Boost
182
My Supra
Hmm, did you do all the clearences by tsrm? or just by what you thought was ok?
Also does the clicking noise ever change? Or is it the exact same intervals between clicks everytime?
danielMA70
14
Germany
The rod bearings are new and the old were not bad...... mmhhh i´dont know if its a piston slap but i checked some videos from youtube and the piston slap sounds like in the vids are different from mine ....always there and realy loud......
I have a stetoscope and i heard several parts at the engine..... its not easy to identify ......so that´s the reason why i´m asking here....... the sounds are like my discription and it is when its warm ......
yes i checked the rod bearing clearance and it was perfekt ......... exhaust leak --> my exhaust bolts are new and the sealing is ok .......
please i´m not a beginner .......
could it be possible that the crank bearings make this sound or the oildriveshaft ???? ..... i never ever had a problem with toyota engines with the crank bearings .... but now i´m not surprized if these are fucked up
The clearance is like tsrm.....
and the intevals are constant like in the video 4-5 clicks......
greetz daniel
danielMA70
14
Germany
Hi mecevans,
yes i pulled every one and it was always there ..... at warm conditions....
its very difficult to say..... so i think its louder at the exhaust side but if i here with the stetoscope an the tootbelt cover i think it is louder at the oilpump direction.....
i think i will remove the cover completely and check all rotating parts...
89supra7mgte
797
colorado
what happens when you give it rpm? does the noise sound faster? or is it a consistent speed? a valvetrain noise will increase with speed. Have you tried disconnecting injectors? may have an injector that is getting noisey. I developed a tick/click noise after installing bigger injectors, mine is purely injectors
danielMA70
14
Germany
Hello guys,
the noise is still there.....
so i was searching about the noise once more and i got some new experiences....
So i checked the ignition with the flashlight.
My idea was so see an axial movement at the crank-pulley....
At this session i found a movement from the ignition angle... while the clicking noise appears.....in the same frequency...
so my new ideas are ... the damper inside the pulley could be damaged.... there is a little visible draft
is there someone who could give me an answer if this could be the clicking noise.....
so i have no ideas mor for that....
bombinuass
431
Dahlonega, GA
danielMA70;1633556 said:
Hello guys,
so my new ideas is ... the damper inside the pulley could be damaged.... there is a little visible draft
now i posted earlier in this thread about my car making the same noise. to mee it sounds in the valve train. but my damper has came loose multiple times untill this last time i was able to impact it. so damage to it could be possibe but to me the sound comes from the valvetrain. same sound tho.
