cleaning up under the hood
PorterzSupra
703
Hebron CT
89Turbo said:
AC components, drops about 60lbs, and frees up HP and some engine space.
Are you joking!!!!??? 60lbs!!?? The AC unit prolly weights a few pounds and the allum heat exchanger and can another pound or 2. Saying it drops 60 lbs is like saying stickers add hp!! When the AC is off the pully is not drawing power and spinning the free rotating pully maybe pick up less then 1/2 a horse if anything. The only thing I could come close to agreeing with is the engine space statement! 60lbs is quite a strech, where did u fabricate that number from? :nono:
Idealsupra
Orlando
www.tampabaysupras.com
id say hes a lot closer then you honestly...
the compressor weighs over 10lbs EASY....
the condensor another 5-10lbs
lines are probably a couple of lbs
and then you have the heater core/blower et al behind the dash which is EASILY 20+lbs...
it adds up
PorterzSupra
703
Hebron CT
I dont think he was refering to the core behind the dash also, dont make me get the scale out... ((stuffs foot in mouth )) lol
8,897
The compressor is 17.5 lbs, and I forget the condensor. The whole system is worth taking. Every little bit counts in weight reduction.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
If you take the heater core out will you still be able to use any of the fans inside of the supra? I'm not sure how all of that is hooked up as I've never been under the dash in mine yet....
shaeff
Kurt is FTMFW x2!!!!
11
Around
^ yes, but you'll have to fiberglass shut some holes (or whatever type of sealer you wish)
i removed my entire A/C system, but keep it bagged up tightly in my garage, should i ever want to replace it. i have no compressor, condensor, lines, or evaporator. it's all gone. the only things left related to A/C in my car are the button on the climate control, and the wiring, which is tucked away and hidden.
-shaeff
supra90turbo
shaeff is FTMFW!
MA, 01440
you can still use the defogger, it's just not as effective without cold, moisture free air blasting away at the windshield.
Dec 3, 2003
6,653
Canada
starscream5000 said:
Ron is running (or was since he is now gone 2J) a fully sequential ignition using six individual MKIV TT coil-on-plug fired by a GM 6-hannel igniter.
Duane
__________________
New set-up coming to a track near you
Ah... I thought i was right about the 2j coils, I've seen most of his videos on cardomain and also noticed in some shots of his engine. Thanks for chiming in Duane.
No problem :)
Duane
supra90turbo
shaeff is FTMFW!
MA, 01440
Duane
d'oh... thanks for the clarification. I thought they were some other coils..
smagnotta
SuprSal
WashPa
I've been pondering the ISC,
Do not take out the Idle Speed Control. If you do you will get a revving idle (go from 1500 RPM down to 500 and loop). This is not something to just take out. Read the TSRM.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Okay, I took out the entire AC system on BOTH supra's this weekend, this is what I have:
The AC pump- aprox 17lbs.
AC condenser and all the lines under the hood related to AC, along with the little fan on the radiator and the bigger fan on the condensor- aprox. 17lbs.
I didn't touch the inside AC System that's under the dash, but I would gues another 10-20 lbs. You all can do the math, that would end up being pretty close to 60lbs depending on the inside portion of the AC.
Another note: the fan on the AC condensor weighs 3lbs, my supe is an '88 and the other (my cousin's) is an '87. His supe didn't have the fan on the condensor:icon_conf , but i added on another 3lbs to the entire wieght and divided by 2 to get the 17lbs because most of us would have had that fan.
On another note, I also removed the charcoal canister on both cars along with cruise control, but I didn't factor in that wieght.
