Chip in the head near coolant passage.
bowsercake
828
Irvine, Ca
Is this chip going to be a problem? I just noticed it after I got the head back from the shop. I'll be using a MHG. Should the gasket seal it in pretty well or is this something i need to worry about?
plaaya69
87T Supra
Nov 18, 2006
947
7
Lake County, IL
I would repair it because if I were you I dont want to think about that once the engine is put together and run into problems later down the road.
p5150
ASE and FAA A&P Certified
Central Idaho
I think you will be fine. If it was on the edge of a combustion chamber I would be worried but you should seal up AOK
turbotrev
Goin WEEEEE on my gsxr600
Aug 7, 2006
311
Clinton, MO
ahhh electrolosis!!! i would get that fixed no matter were it is b/c that will just keep getting bigger and BIGGER!
p5150
Central Idaho
I agree with jdub -
If you are worried about it take it back to the machinist and see what they can do to help you out. They can probably just fill it in a bit with a weld and re-surface it very easily.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
jdub said:
I would never use a copper spray sealant on a new MHG........
Using it would be a good way to ensure it doesn't seal ;)
And where is you're proof of that? I know you say that theoretically it will break down the viton, but in real life experience I have not seen this cause any detrimental effects. I have built lots of engines with copper spray on a new HKS mhg with a 100% success rate. Even if it did break down the (much too thin) viton layer, the copper is still on the gasket surface.
I have, on the other hand, seen engines built with a mhg and no copper spray have slight bhg's where the cooling system gets pressurized from the combustion chamber enough to cause major problems.
I wouldn't say anything if you weren't so vocal about it, but I have seen you posting about it all the time.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
What's to say the breaking down of the viton doesn't help the two sealants bond together? They must solidify in some way with heat, or neither would create a permanent seal. Also, did you research which of the chemicals in the copper spray evaporate with heat or just exposure to air?
There is no doubt in my mind that copper spray on an HKS mhg works absolutely great, not in theory, but in reality and in practice. It has been tested on engines that saw all different levels of horsepower and boost, and all different types of abuses from detonation to melted pistons, with no failures of the gasket seal.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
IJ had a bhg because he was running too lean on propane at very high boost levels. The type of gasket sealer he used, if any, didn't cause the failure. At a certain point, something has to give. Reguardless, I haven't used a Cometic headgasket before, so I can't comment on those.
IIRC, the gasket that IJ blew was a HKS stopper headgasket, that he bought from me, that he didn't use any spray sealant on.
johnathan1
Supra =
Aug 19, 2005
5,056
The instance I am thinking of was probably close to two years ago now...and he said that something in the brake quiet turns the Viton coating to goo...and that that coupled with his use of green coolant is what caused his BHG around the #6 cylinder... I don't even remember what thread that was in...probably his big build thread which is pretty much stripped now.
Maybe your thinking of a different time? Or maybe I just read wrong...:icon_razz
mattjk
Permanent Ban
May 18, 2006
1,973
Huntington Beach
HKS USA Chief Engineer Howard Hoshko instructed my friend and I to use copper spray on their gaskets. I'd listen to him before any "internet genius'"
jdub said:
BTW…I couldn’t get HKS to talk to me ;)
my friend and I are personal friends with him, and most of the good old hks people... so that helps.
Mine was a Cometic that let go at 30 psi 8300 rpm......
Where it had blown was scoured clean of Viton and the margins of what remained was slime.
The HKS Stopper DIDN'T blow I lost a cylinder after leaning it out during a top end run. (Closed a ring end gap and trashed the bore)
I know it's only anecdotal evidence but I would use that combination again.
As for being an "internet genius" Most of what I post is personal experience nothing more I've never made myslef out to be some genius or guru, I learn by doing not by reading crap posted on the net.
quake
toyota tech
Apr 13, 2005
619
r.i.
crap posted on the net lol
