You can get a Recal done by Jet Chip. I did a while back. You order the "kit" they send you a box to ship your ECU back to them They recalabrate it and ship it back. They change the fuel curve so they say. Can't say that I noticed that much of a difference. I changed to an Apexi, and that gives you a lot better control over things. I'm changing to Maft-Pro speed density now. That's suppose to give you more control and you can get rid of the AFM:naughty:Projectmk3 said:Does anyone know of anything i can do to upgrade my ecu?
AJ'S 88NA said:You can get a Recal done by Jet Chip. I did a while back. You order the "kit" they send you a box to ship your ECU back to them They recalabrate it and ship it back. They change the fuel curve so they say. Can't say that I noticed that much of a difference. I changed to an Apexi, and that gives you a lot better control over things. I'm changing to Maft-Pro speed density now. That's suppose to give you more control and you can get rid of the AFM:naughty:
GrimJack said:I think Reg Reimer still does ECU upgrades out of Alberta, Canada as well, but from what I've heard, the cost is equivalent to buying a standalone...
drjonez said:no, they don't.
http://www.4cefed.com/jetecuscam.html[QUOTE/]
Wish I would have known that way back when I had Jet put the $160.00 sticker on it. They should have atleast put a SUCKER sticker on it too.:cry:
Thanks Doc hope somebody reads this before they make the same mistake I made.
