Definition: An expansion plug located in the side of an engine block that is supposed to protect the block against freeze damage. Water expands when it turns to ice, and if the coolant doesn't have enough antifreeze protection it can freeze and crack the engine block. The freeze plugs (there are several) are supposed to pop out under such conditions to relieve the pressure on the block. Freeze plugs can often be a source of troublesome leaks as a result of internal cooling system corrosion. Ease of replacement depends on accessibility.
Your auto teacher IS wrong. And the technical term is "expansion plug" but most commonly called a freeze plug.
