Check out my pics :[ (carnage)
jimi87-t
1,126
4
Colorado Springs
You had ball bearings bouncing around inside your combustion chamber? :aigo: No you can not have the inside of your combustion chamber having high metal, this makes hot spots that cause detonation.
How the hell did debris that big get inside your motor?
EDIT: Ok, (now that you posted pic of the screw), how the hell did you have a screw in your motor?
C
cnewingham
Guest
OUCH. How the hell did that screw left there? Were you in a hurry??
tte
Breaking In - in progress
Northern California
I am referring to the 9th and 10th pics.
There seems to be a dent on the bore. Is this dent on the head?
If it is, it looks like the piston couuld have hit it.
I have seen a N/A with a very bad rod knock where the the rod punched a hole through the block just below the oil filter location. And it did the same damage.
Cheers,
Roy
