tissimo;1173678 said:When you jump Te1 & E1 the CEL is solid and doesn't blink? Or just doesn't come on?
supramk3man;1173695 said:Are you sure that you got the Te1 and E1 conected. On my 1jz i had the same problem and it turned out that the pin in the te1 spot got pushed to far down in the holder and the wire wasn't making a contact. So i got a little nail and put it down in there and made the contection that way. Might want to get a flashlight and look down in the E1 and the Te1 spot in the little box.
Zerocool;1173729 said:Israel it sounds like your TPS, if you want give me a call tomarrow and if your willing to travel a distance ill be more then happy to check it out for you .
bluemkiii;1174884 said:Well I figured out the problem the voltage on the battery wasn't full and It doesn't blink if the battery is dead or doesn't have good voltage. Also my car isn't throwing any codes but it still runs like crap.
Its wierd because sometimes it idles good but I can't rev it. And other times it idles crapy but it revs good. What could be causing this? Also when I press on the brake pedal, the car wants to die but it doesn't, the idle just goes down but then jumps back up so basically on the initial press of the brake pedal the car wants to die. Hope that makes sense. I'm starting to think its the fuel pump but sometimes it revs good, but then again it could be on its way out. Thanks for any help or advice guys I appreciate it.
suprahero;1184338 said:It sounds like a vacuum leak. Have you checked all of your lines to make sure they're connected good and no holes in them? Make sure and check the line running to your brake booster as well. Good luck.
