Ok I had a thread that is now lost in obscurity and doesn't really match my current problem anyway.
As some of you know I have a problem with my charging system, meaning, it doesn't work. The battery is not receiving any charge from the alternator. I have used several different alternators that have been tested after I used them and they are in working order. I have replaced all fuses and some of the wiring that needed it. The battery is only a few months old and is able to charge up to 14 volts from a battery charger. I have continuity in all wires that run to/from the alternator to their respective locations whether it be the fuse box or battery.
Any thoughts?
Any thoughts?
