jdub;1116474 said:There are 2 check valves: One in the charcoal canister and one in the gas cap.
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?Section=EC&P=6
These are there to regulate flow to the charcoal canister and prevent vacuum in the tank...the fuel feeding the pump needs to be under positive pressure (2 psi iirc) to prevent cavitation. The check valves are there to make that happen.
thanks jdub ill put in a 2psi check valve on the vent line and dump the line at the rear of the car. right now it vents in the engine bay but i wasnt sure what to do with it.
(note this is just on my race car that gets driven twice a month and thats it. my daily supra has the canister still on)
