charcoal canister
blacklightnin55
Ex SoCal Street Racer
Aug 10, 2005
9
Slidell, Louisiana
i am in the process of swapping a 7mgte into a toyo 1990 ext-cab pick up. i was wondering how important is the charcoal canister and can i hook up my return fuel line without it?
N
NDBoost
Guest
i have mine removed, emissionse wise you will more then likely fail if its removed. For now all i have is it taken out and a piece of fuel tubing connected to the vapor line, that goes to under the car. The other option is to cap the vapor line off and just buy a vented gas cap.
EDIT:
http://7mpwr.com/pictures.7mp?i=P10100114.JPG
up along the firewall youll notice the little red cap, that line used to goto the charcoal canister.All i did was I capped the tubing off and then just bought a vented gas cap.
Heres another angle (passenger side)
http://7mpwr.com/pictures.7mp?i=P1010022.JPG
blacklightnin55
Aug 10, 2005
9
Slidell, Louisiana
thanks, i live in a state that does not emission checks or regulations. like i stated i'm doing a swap. don't really know the in's and out's of the 7mgte but i am learning. one other question? where is the turbo pressure sensor on the supra located. i did not know i needed one. saw one for sale on e-bay for the same year engine that i have (1987). is this the sensor located behind the glove box?
N
NDBoost
Guest
If you are referring to the Boost sensor for the boost gauge it is on the drivers side near the cruise control, let me update this thread w/ a pic of it circled
EDIT:
http://img209.imageshack.us/my.php?image=updated4ej.jpg
that is the sensor for the stock Boost Gauge, there is a vacuum line that T's into the cruise control line and the connecter goes into the cockpit :)
edit:
mind the nasty engine bay, that was pre head gasket job :)
