Charcoal Canister/ Engine Bay cleanup...
RiyadYar
384
NY
will removing the CC create a gas smell. because since i bought my supra their's been a gasoline smell evertime i drive it. i thought it was caus e i had no cat. but could it be because i have no CC?
Oct 11, 2005
3,819
20
Thousand Oaks, CA
jetjock;927069 said:
Finally, for those in California pressure testing of the EVAP system up to but not including the cannister is now required on the smog test, beginning this year.
Is this already in place? I had a smog two weeks ago and the tech tested the cap, but I didn't notice him pressurize the tank?
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Yeah, doesn't apply in that case. I was assuming you had the Supra tested. Before you go in borrow a Magnehelic from the guys at work, bust loose the line at the EVAP cannister and put, I dunno, say 30 or so inches H20 in there. If it holds you're good. A slack tube will also work. Cheap enough to make ;)
applesauce
Banned Scammer
Aug 24, 2006
705
Virginia
Okay, I will keep it. That sounds like the smarter thing to do. I will find a way to clean it all up. Thanks again for the input, and im glad some other folks had there questions satisfied also.
