changing out my clutch
You can do it, but it isn't as easy as getting a hand job from a female celebrity, and it isnt as hard as saying no to a highschool gymnast either.
Read the instructions and you can do it.
87supra
importrage2
Mar 12, 2006
9
Colorado Springs
sorry i took so long to update. well my luck i got the tranny out and when i did my fly wheel bolts were broken. parts of it were still on the moter. im kind of intimidated to try to tap them out .. what should i do in this case. should i just order my bolts and finish what i started or consult with a shop?
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
if you can simply unscrew the broken ones from the crank just do that and put nre bolts, if not dont mess with it before you get a professionals opinion. Once you screw up the crank youre in trouble.
Did you break them trying to remove them, or where they already broken?
Once the stress of the head of the bolt is off them, they usually come right out if you can get a grip on em...
