I have about 3k on the new engine now and I just bought some Mobile1 with a new filter... anything I need to do special other than normal to change over?
macsupra76 said:Change the oil, cross your fingers , hope theres are no leaks.
If the engine is new you should be good.
What weight are you using?
Justin said:5-30, its cold as hell here and I read/heard its the best way to go in the cold.
three identical vw engines all running fine before i put this oil in and then everyone of them has had the same thing happin it's also happined to quite a few people on vwvortex.com. trust me i though my engine was screwed at first but checked the dip stick and was like wth then went home and got on vwvortex to find it happens when you put 5 or 10 in it. also have a oil pressure gauge in one of my cars and watched the gauge as the buzzer went off and the pressure was fine.shaeff said:^ for some reason, i think you have other issues, not related to the oil...
-shaeff
jdub said:Justin - the Mobile 1 5W-30 will be just fine...in fact you can run it all year round in your new motor. Just check to make sure you are getting pressure in the TRSM spec at idle and 3000 rpm at operating temp. Don't be tempted to run a ?W-50 oil...ever. Actually a ?W-40 is a bit thick for a new motor. I've posted quite a bit of info on oil lately, do a search and it will show.
The filter is as important as the oil you choose. Wix, PureOne, Napa Gold are all excellent. Fram filters are garbage.
GrimJack said:Hey jdub, what's your opinion on authentic Toyota filters?
Justin said:Thanks for the input dude.
A buddy told me to do 5W-40 in winter, and 10W during the summer. He seems to know his stuff on oil so I figured I'd listen. If I can do 5W all year round might as well just do that
I use napa gold as I've been told by a number of guys that it is just a re-badged wix filter
jetjock said:That German Castrol stuff sucks...too thin
