Celica Swapped 1JZ - In need of Fuel Pressure Regulator?
SupraFreak13
1JZ Drift Celica
Jan 3, 2009
66
Baltimore MD
I know it's not a China Walbro...I got it from a reputable source while I was working at a well known performance shop.
Today I put a new fuel filter and changed the oil and oil filter. It's still breaking up once the RPM's climb under load. I need to pull the inlet line to the fuel pump and see how it acts with less hose and no restriction.
I spent the last hour trying to upload a video I took, but I can't get the quality any better for some reason...it's hard to hear clearly, but you get the idea.
http://www.youtube.com/watch?v=zm2KH7WT7to
Every time I step on the gas it will run ok at lower RPMs then it breaks up and then won't rev anymore.
SupraFreak13
1JZ Drift Celica
Jan 3, 2009
66
Baltimore MD
Evilempire1.3JZ-GTE;1273922 said:
Also to let you know I have got the top of my engine wet cleaning it the coils do not like it at all it ran like crap cracks in the coil is bad.
Yea, I know I have one cracked coil for sure. But I've read on here that even with a lot of spark scatter it should run fine at lower boost and power levels. Its seems it only cause a real problem when people try to turn up the boost. I still think I have some kind of fuel line restriction, or the pump itself went bad, maybe from running with air getting in the line, causing the pump to burn up prematurely.
