I'm trying to get my 1JZ celica running right. When driving, the motor sputters/cuts out if I get on the throttle heavy, and when the boost gets at or near positive PSI. I have been searching SM since Jan and I've tried lots of things that I found here, but haven't solved the problem. It has;
-Walbro 255 external pump, new braided steel fuel feed, using the OEM celica feed line as the return.
-JDM 440cc injectors
-3" turbo back exhaust
-2.5"/3" intercooler pipes with decent sized front mount
-NGK BKR7E plugs .032 gap that they came with.
-HKS SSQV
The most recent progress I had is when I hooked up a fuel pressure guage. It is 30-35psi at idle. Just yesterday I took it out and when I get on the gas and the motor is about to boost, it cuts out, and the Fuel pressure drops to around 20psi...From that I would think it's the Regulator. I have not checked the voltage at the pump, is it more likely the regulator or the pump voltage?
If anybody has an OEM 1JZ regulator that you know is good I'm trying to buy one to see if that is the problem. I was thinking about getting an Aeromotive, but I don't want to spend the cash if I'm not positive that's the problem.
any help would be greatly appreciated, and if someone has a 1JZ regulator please let me know!
-HKS SSQV
